305 tbi build
Old Jul 8, 2010 | 06:44 AM
jay173's Avatar
305 tbi build
so what are the best heads i can pull another camaro for our 305s my 305 is not very old since last owner purchased a long block after blowing old one up
dont say 350 because many 350 things work on 305
Old Jul 8, 2010 | 01:31 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Re: 305 tbi build
I've read a lot about Vortec heads being the best choice followed by a set of 081's.
Old Jul 8, 2010 | 01:40 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: 305 tbi build
Agreed with the above. A good set of ported Vortecs will boost you into the 350+ power range with about the same amount of TQ on a 305.
Old Jul 8, 2010 | 02:50 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: 305 tbi build
I think engine quest offers a vortec head in a standard bolt pattern for your intake, that way you dont have to buy a vortec TBI intake, BUT a better intake is recommended. Also, make sure the engine quest castings are the better performance versions for more lift. People often want the 062 or 906 castings because they flow the best. Some want the 059 305 Vortecs which I have heard can be massaged to flow very well. Just keep in mind tuning and a few other TBI goodies will be required after the swap to get maximum results, but ill let the TBI guys tell you whats best... Later.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
