key will not turn off
Old Jul 13, 2010 | 05:18 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
my key is stuck in the on position it will not turn off. car starts and runs fine just the key will not turn off. is this my igntion switch or something broke in the steering column? i have to disconnect battery to turn the car off. i have tried wiggleing the steering wheel and the gear selector no luck. if i force the key off will i break something else? thanks for any help.
Old Jul 13, 2010 | 05:21 PM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Re: key will not turn off
gotta replace ignition lock cylinder in the steering column, went throught the same thing last year with mine.
Old Jul 13, 2010 | 06:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll have to get a VATS ignition cylinder as a replacement - unless you've bypassed VATS already the lock cylinder will have to have the contacts inside to "read" the key pellet. After install, you'll need to get a key that is cut for the new lock (new lock will come with a plastic master), but that new key will have to be made using a VATS blank that has the same resistor as your old key - so take both keys with you. Any ACE hardware can cut VATS keys for $25 each.
Old Jul 13, 2010 | 07:10 PM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
when my key got stuck on the on position, I got a new ignition lock cylinder with a new key to match at a chevy dealership and then installed it. Turned key and car started haven't had any problems since. I'm not really sure where the vats come into this issue. I am aware of the chip that is on the keys that is why it was suggested to get a new key to match.
Old Jul 13, 2010 | 07:18 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
yep new ignition lock cylinder is what you need. you are going to need a spring compressor to remove the metal ring in the steering column behind the wheel. its not that bad of a job just remember where everything goes.
Old Jul 13, 2010 | 07:21 PM
Car: 1992 RS
Engine: Carbed 350
Dealership must have made your new keys based on the resistance of your old key pellet, whether they got that value off your old key or by a VIN number. The VATS module is programmed to 'look' for a certain value - if it does not get it, it won't start. There are 15 values. You MUST have keys made twith a pellet blank that matches the value YOUR car has been programmed to. Only other option is to bypass the VATS by giving it the resistor it wants by permanently attaching that resistor inline.
The steering wheel removal tool is available as a "free" rental at most any parts store.
You can get the lock cylinder at most any parts store as well, I'm assuming much cheaper than the dealer - mine was about $60 but that was 5 years ago. And like I said, ACE can cut the keys, just take the new plastic master and your old key so they can get the resistor value from old key.
Old Jul 13, 2010 | 08:38 PM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
correct I could have gotten the lock cylinder from a parts store, but they wouldn't match up the key that went with it. told me to go to the dealership and get both, shot two birds with one stone I guess.
Old Jul 14, 2010 | 06:44 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
thanks for the help. so a lock cylinder it is. i have already bypassed the vats for my ls1 swap so i should be good to go. thanks for the help.
WIzmo
Aug 30, 2015 02:30 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
