Engine stalling...need help.
Old Jul 14, 2010 | 05:24 PM
bigbandwith's Avatar
I have a 92 TA Vert TPI 305. I was running fine for the longest time. It idles and revs nicely but stalls under load. It doesn't stumble it just cuts out when you accelerate. SES light also came on a week or so ago. Where should I start. Thx.
Old Jul 14, 2010 | 06:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start by finding out what fault is turning on the SES light.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Jul 15, 2010 | 07:59 PM
Re: Engine stalling...need help.
Oh brother!! So I used the paperclip method to short the OBD.
I get the first readout which I assume is 12. Flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause.
How on earth do you decipher the rest of the codes?
Old Jul 17, 2010 | 09:34 AM
OK, buddy of mine tells me I am getting a code 22. I guess I should start with replacing the TPS?
Old Jul 17, 2010 | 05:32 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Yes it should flash 12 three times , then the remaining flashes will tell you what is going on. Code 22 is Tps I believe. Let me know how it goes
Old Jul 17, 2010 | 05:33 PM
ninetyone's Avatar
Axle/Gears: 3:42
http://www.gmtuners.com/OBD1_DTC.htm That is a link for obd1 GM trouble codes.
backtothe80s
Sep 5, 2015 12:39 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
