2500 rpm idle
Old Jul 22, 2010 | 01:03 PM
1rogue86's Avatar
Car: 86 iroc
Engine: 305 tpi
2500 rpm idle
ok i have an 86 iroc 305 tpi, when i got the car it had an extremely low idle. so i adjusted the tps, and then i ran good, now when i start the car it decides its goin to idle at 2500 rpm. i can drive it around get it warm and drive around but it will still remain at the high idle. so i decided to pull off my throttle body and clean it up, the iac and tps are sappose to be new from the previous owner, so where do i go from here. other then vac. lines bad, but its intermittent, somedays it will idle perfect others it will idle at 2500 rpm and sometimes it will even be like 500 and surging. any ideas?? also would my cts have anything to do with this, because it seems to have alot of control on somethings.
Old Jul 22, 2010 | 03:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 2500 rpm idle
when you did your TPS did you follow the tech article??
Old Jul 23, 2010 | 04:15 PM
1rogue86's Avatar
Car: 86 iroc
Engine: 305 tpi
Re: 2500 rpm idle
ya i adjusted the tps and set the idle set screw so it was fine, but then it randomly just started to do this crazy idleing
specialized
Jun 18, 2022 09:26 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
