Discoloration between intake runners?
Old Jul 24, 2010 | 10:43 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yesterday went to the dyno. Did 340RWTQ @ 3200 RPM or so, 291 RWHP @ 5200 RPM. I think I have a vacuum leak since they couldn't get the carb to run correctly even after swapping jets (96s), squirters (37s), etc. Then I blew coolant all over the place out of the water jacket by the #1 intake runner. I torn it apart this morning for new intake gaskets and noticed the right and left runners aren't showing the same coloring. It looks like the #1, #3, #5, #7 are all super clean like brand new out of the box. Could a water leak be causing this or do I have bigger concerns?
Old Jul 25, 2010 | 08:48 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Discoloration between intake runners?
puzzling. all I can say is that I'll think on it a bit.
Old Jul 25, 2010 | 09:35 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
That is wierd but those numbers seem really low for a motor like that.
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
