Pilot bearing needed with a 700R4??
Old Jul 25, 2010 | 05:23 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I just put my engine together and I'm getting a horrible vibration. Almost like when I had my V6 2.8 with a T-5 and didn't have a pilot bearing in the crank.
I just completed a 357 swap. Started it up and I'm getting a crazy vibration around 1k rpms, my idle at the moment. When I was installing my 700R$ I did notice a PILOT BEARING installed but didn't think I'd have to remove it.
Is this the cause of my vibration? Thanks for any help!!
Old Jul 25, 2010 | 07:36 PM
Re: Pilot bearing needed with a 700R4??
I posted this in the right section.
Mods if you could delete or lock would be great. Thanks!
Old Jul 25, 2010 | 09:38 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Yes, you needed to remove that pilot bearing. The torque convertor isnt sitting in the crank far enough and you might have messed up the trans, convertor, or front pump.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
