what is this ?? pics
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
what is this little unit, the line runs to the throttle body?? and whats the sphere bolted to the body underneath it?
Re: what is this ?? pics
I'm pretty sure that the "sphere" might mean the vaccuum accumulater ball located under a short horizontal forward part of the inner fender panel.
Vaccuum lines run from the engine into the ball where it can store up a greater "volume" of vaccuum, and then out of it, to run different things on the car such as the air conditioner/heater/defroster air flow doors up under the dash, and other things. I think cruise control is run by vaccuum too.
Car: 1990 Iroc-Z28
Engine: 350HSR
so would it really do any harm to take it outa there? probably no harm leaving it there, just more crap though
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Cruise control, your choice.
Vacuum ball - I'd leave - without it your HVAC controls are not going to work well, will take a long time for vent positions to change, etc. If you do, realize that you need to plug the line or else you have a vacuum leak.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1990 Iroc-Z28
Engine: 350HSR
think im just gunna leave it, glad GM at least hid it under there!
also another quick Q if u guys might know, those 2 brackets on the front of the engine that hold all the acsessorys and alternator ect, can you pick them up off of GM trucks aroudn that year or anything?
Car: 1992 RS
Engine: Carbed 350
Car: Camaro Z28 '85 T-Top
Engine: 5.0ltr 305 cu.in
Transmission: TH700R4
Axle/Gears: POSI axle, not sure gear ratio.
I believe that is a fuel surge cannister to trap excess fuel.
Hope this is right and useful.
