starter issues.
Old Jul 29, 2010 | 08:43 PM
MT85camaro's Avatar
Car: 1985 Camaro SC
Engine: 305 V8
starter issues.
so my starter went out in my 85 coupe with a automatic 305. I got everything unbolted and taken off but i'm having trouble getting the starter out from within the car. anyone else had this problem? the exhaust pipe comin from the engine is in the way and all i need is like half an inch more clearance and it would slide out? what did you guys have to do to get yours out?
Old Jul 29, 2010 | 09:17 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: starter issues.
Once you disconnect the wiring and unbolt it hold it as if was still attached and move it forward turning it to allow it to go as far forward as possible then turn it downward while turning it to clear its way out, reverse to install.
Old Jul 27, 2011 | 10:14 PM
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
Re: starter issues.
did this work? and did u have to take the "bracket that is on the back of the starter", off the block?
Old Jul 28, 2011 | 10:35 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Re: starter issues.
I have removed the solenoid before, then reinstalled after sliding the starter up past the a-arm. Another time - it just worked without needing that extra space.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
