Heads cam question
Old Jul 30, 2010 | 09:55 AM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Heads cam question
Im looking to do head cam and intake this winter and im trying to get some opinions. I want to get my car to run low 13s. Any ideas?
Old Jul 30, 2010 | 10:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Heads cam question
still too vague, too many ways to go. keep it TPI, or go HSR? does the budget permit AFR 180 heads, or if not, are you up to porting Vortecs? If not, what is the budget for heads?
Picking a cam depends on your answers to which heads and which style of intake.
Old Jul 30, 2010 | 01:38 PM
Transmission: 700r
Looking to do a stealh intake. trying to do a 1500 parts budget but will go over if it takes to get into low 13s
Old Jul 30, 2010 | 07:35 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I think I can get you really close. I propose this: start with these heads: http://www.competitionproducts.com/R...fo/RHS12410K1/ then this cam: COMP 08-000-8, 3015/3037-114, and the Holley Stealth Ram Vortec intake manifold.
Old Aug 2, 2010 | 12:13 PM
Transmission: 700r
How much HP/TQ will I gain from this. And where can you find the specs for the cam
Old Aug 2, 2010 | 08:12 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It'll get you to your goal, for close to the $ you typed. I gave you the part number, the 000 in the middle indicates a custom grind. then the 4 digit intake lobe number, then the 4 digit exhaust lobe number. each different lobe has a different 4 digit number to identify it. the 114 is the lobe separation angle. The lift comes out to 0.537/0.536" with 1.5:1 rockers, which is what you should use with this combo.
Old Aug 3, 2010 | 04:31 PM
Transmission: 700r
Ok thank you for your help
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
