Will this intake work?
Old Jul 31, 2010 | 07:03 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
Been doing some research and came across a new intake from Holley that I think could help me bring some new life to my old and tired 2.8. Now I know allot of you dont care for the 2.8's but I'm simply just playing with ideas. So here are my questions:
1) will this intake work with my 2.8?
2) will it require any mods to make it work if it wont work as a bolt on?
3) would there be any significant increase in throttle response and/or HP if this intake would work?
Keep in mind that the 2.8 I currently have is completely stock and has high mileage. Thanks in advance.
http://www.holley.com/550-811.asp
Old Jul 31, 2010 | 09:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Will this intake work?
Must be the wrong link, that intake is for a V8, while your 2.8 is just a weak V6. The only aftermarket intake is the Truleo. For more info, read up on Pennock's Fiero Forum.
If you want the most from a 2.8, then swap the 3.4 from a '94 or '95 camaro.
Old Jul 31, 2010 | 09:16 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
OK, I feel like an idiot now, I didnt notice that I was looking at V8 intakes. Sorry for waisting anyones time. I assume your talking about the intake from a 3.4? That's easy enough, ebay has several for around $60. The same questions apply. Thanks.
Old Aug 1, 2010 | 04:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No, you can't use the 3.4 intake. You can put the 3.4 engine under your stock 2.8 intake or under the Truleo intake.
Old Aug 1, 2010 | 04:48 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Also, Smokey Yunick himself declared the 2.8 intake to be "a good design, not a restriction". The only way to improve on it is Extrude-Hone, and that's pointless unless you're putting it on the 3.4
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
kyle5647
Aug 15, 2015 11:56 PM
