battery ground keeps frying
Old Jul 31, 2010 | 09:07 PM
Slowvert92's Avatar
Car: 91 WS6
Axle/Gears: 3:47 one legger!!!
the small gauge wire coming from the battery terminal to the chassis keeps getting fried. ive replaced the the ground cable twice and keep getting same result. after 5 or 6 starts it melts the casing around the wire and it wont start anymore. any suggestions would be greatly appreciated! THANKS.
Old Jul 31, 2010 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: battery ground keeps frying
whats the condition of the large ground cable going to the engine. Also, there is a ground strap on the rear of the passengerside head to a stud on the firewall by the heater box. Make sure they are both there, in good shape, and tight. It sounds like you lost the main ground and all the current is running through that little wire to the fender
Old Aug 1, 2010 | 12:11 AM
Slowvert92's Avatar
Car: 91 WS6
you know of a good spot on the block for a ground? i have it on the alternator right now. specific bolt location would be nice. thanks!
Old Aug 1, 2010 | 03:39 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You should have aground going to the passenger side serpentine belt bracket.
Old Aug 1, 2010 | 06:46 AM
Damon's Avatar
Agreed with above- your main ground connection (negative battery cable) is bad. It's using the little chassis ground wire to find an alternate path to get juice to the starter (which draws a LOT of amps). Bingo- fried chassis ground wire.
There is a stud on the pass. side serpentine belt bracket underneath the A/C compressor (above the smog pump) specifically for attaching the negative battery cable.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
eustodp
Sep 20, 2015 05:09 PM
gta892000
Sep 16, 2015 12:37 AM
