Is this a roller engine?
Old Aug 2, 2010 | 04:46 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Just wanting to know if this engine has roller lifters?
Thanks!
Old Aug 2, 2010 | 08:56 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Is this a roller engine?
yeah it is a roller motor you can tell from the hold down spider in the middle of it, flat tappet hydraulic cams don't use that. You are posting in the wrong section though this will more than likely get moved.
Old Aug 2, 2010 | 09:18 AM
Stephen's Avatar
Car: 87 GTA
https://www.thirdgen.org/sbc-camshafts-primer
Old Aug 4, 2010 | 12:10 AM
85 ZXX's Avatar
Its ok if it gets moved, Both of you gave me the answer that I needed to know! Thank-you for the info!!!
Old Aug 4, 2010 | 12:47 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
And clean that coolant out of your oil.
Old Aug 4, 2010 | 11:43 PM
85 ZXX's Avatar
Getting it reassembled now.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
BrianI
Aug 9, 2015 11:52 AM
