lt1 for drift
Old Aug 2, 2010 | 04:06 PM
brad99's Avatar
lt1 for drift
i heard that the lt1 cant handle the stress of drifting is this true, is there any thing i could do to improve that
who makes cams and heads for the lt1 i know of edelbrok, comp cams etc but are there any one like Texas speed for the ls1
Old Aug 2, 2010 | 04:12 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: lt1 for drift
anything can drift, its all in the driver and expirence. people think u have to hold it in high rpm all day long.. na its all in the use of ur brake,gas and steering. gears and lsd have a play in it to.
a stock lt 1 is a good place to start, good hp/tq main deal is it a 6 speed? what r the specs of the car?? i drift with a t5/semi built carbed 350. and i do good, most of my luck is because how i sat up the car.
Old Aug 3, 2010 | 02:18 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: lt1 for drift
Stock VS stock, an LT1 is a better built engine than any of the Gen 1 small blocks.
Old Aug 3, 2010 | 03:16 AM
sahibkalra1's Avatar
Car: 1991 pontiac firebird formula
Engine: v8 5.0
Transmission: automatic
Re: lt1 for drift
the benefit of lt over the generation one is that it's lighter...more power....and overall efficency...so yes you can use the lt to drift as long as you have all the other mods done specificallly for driting..."upgrade the suspension, springs, torque arm, get frame connectors" also don't forget if you are going to drift there are specific upragdes for brakes but i am not too familar with that...
Old Aug 3, 2010 | 03:20 AM
Engine: v8 5.0
Re: lt1 for drift
well i forgot to mention...your tranny and your rear end is really gonna take the beating soo make sure to take care of that...
dustint209
Nov 26, 2015 12:28 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
ULTM8Z
Oct 2, 2015 01:25 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
