I need answers....
I have a 87 trans am, its a carb. 305, 5 speed with 110,000 miles
Gears seem really tight to where im almost forcing it into gear at red lights, but havent noticed any slippage,
Takes off pretty good, but once i get to about 3000 rpm in 2nd gear i lose almost all power
is my motor just getting tired and not wanting to put out the power?? or could the clutch be going bad??
Note: No rod knocks===== starts fine------ and doesn't miss ---- but there is a weird humming noise.
Check the fluid level in your clutch's reservoir, then check for leaks along the master cylinder, slave cylinder, and line. If your clutch is going bad, typically you won't have a hard time getting into gear at all since it will be slipping.
