AC compressor manifold assembly
Old Aug 3, 2010 | 03:42 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Hey guys, can someone please take a picture of the connector on the back of their stock compressor, the inside part of the connector - the part you can't see when it's all bolted together. I'm in the middle of a battle with this car, and can't seem to figure out what is right and what is wrong.
I tried replacing my ac compressor with a brand new one for the car and the one I got for it (p/n 58941) does not have the same style connector on the back as my old one did. The old one i have is made to use o-rings set into grooves in the ac compressor, with equal height when compared to each other. The new one uses some sort of stepped or offset gaskets, not really sure, but the o-rings that i have for the ac system for the car will not work in it.
I'm trying to find a new manifold assembly to put in the car so I can use this new compressor and finally have ac in my car again. I would love to see some pics since it's a lot easier to understand. If anyone has any pics of their stock system apart so I can verify which type of connector is right I would really appreciate it.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
