Diff fluid leak
Old Aug 4, 2010 | 10:32 AM
AKATDOG's Avatar
Car: 84 Z28
Diff fluid leak
i just did a rearend swap a week ago, today i look under the car and see a small amount of fluid coming from where the drive shaft goes onto the diff, you can see a drop of oil coming off one of the four nuts that hold the driveshaft in place, any seals there to change? or where else may it be leaking from?
Old Aug 4, 2010 | 11:08 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Diff fluid leak
Gear oil will leak past the splines of the pinion shaft. There is a seal to prevent this on the yoke but it gets old and begins to fail. Remove the pinion nut. If the pinion seal is also leaking, replace it at this time. Clean everything real thoroughly with brake cleaner, fill the cavilty under the pinion nut washer with "The Right Stuff" and reinstall the nut.
Old Mar 6, 2011 | 02:40 AM
CuriousPrimate's Avatar
Re: Diff fluid leak
Whats the right stuff?
Old Mar 6, 2011 | 03:22 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Diff fluid leak
The Right stuff is a heavy type of RTV from Permatex. Find it at most any parts store.
Old Mar 6, 2011 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Diff fluid leak
A How-To for replacing the pinion seal can be found in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
junior419
Apr 7, 2025 11:35 AM
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
carattini
Sep 10, 2015 07:46 AM
rudolphschenker
Sep 4, 2015 02:41 AM
