ZZ4 Engine
Old Aug 4, 2010 | 06:50 PM
metaluzc's Avatar
ZZ4 Engine
I was looking at a '92 Camaro RS for sale on eBay that claims to have a ZZ4 350/355HP crate motor mated to 6-speed tranmission out of an '02 SS Camaro. While looking up the ZZ4 engine, I ran across many forums with people hating on this engine, some because of the recommendation to not go higher than 5500RPMs. Does anyone have experience with this engine and had any problems? Is the 355HP/400lbs Torque at the wheels? What potential problems would one face if they continually shifted at 6000RPMs or higher instead of the 5500RPM limit?
Old Aug 4, 2010 | 07:04 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: ZZ4 Engine
well to start with, the person selling that car doesn't know much about engine swaps, because unless they went through extra trouble to adapt the ls1 t56 to a sbc the 6 speed would have been out of a 1993-1997 lt1 f-body.
i have a zz4 in my car and it's a reat motor, it has 25k miles on it and i;ve never had any problems, i take it to 6k rpm every time i drive it, but power starts falling off at 5k to 5.2k rpm so over-revving it wont do you much good. its a fun little motor that will last forever if you don't spray/boost it and run a god tune on it
and i dyno'd mine with a 6 speed and d44 rear end on dynojet, was at 300rwhp and 355rwtqq
Old Aug 4, 2010 | 10:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ZZ4 Engine
Never seen that , only rev limitation would be the cam as stated above
Most popular SBC crate engine every made ;Why?
Check this out
500+Hp @ 6400 on stock ZZ4 crank with head / cam change
http://www.chevyhiperformance.com/te...ild/index.html
Engines are rated at the crank
Old Aug 5, 2010 | 09:07 AM
metaluzc's Avatar
Re: ZZ4 Engine
I am just going by what the listing said; http://cgi.ebay.com/ebaymotors/1992-...item2a092b5fc6
Well the reason I asked if that was at the wheels is because I saw a Dyno sheet for the motor and it came out to be the 355HP and I thought Dynoes tested the wheel HP; http://www.mycratemotor.com/pdfs/Dyno12499712.pdf.
I might have been a little low with the RPMs, but it says here that the recommended MAX RPM should only be 5800; http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999
Do you have any 1/4 mile times sailtexas186548? 300 at the wheels is pretty good to me.
Old Aug 5, 2010 | 10:09 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: ZZ4 Engine
my personal best is..... 13.7! lol at 106.7 mph, and thats with a 2.1sec 60 foot spinning 1,2, and some of 3rd . i was on old street tires...
i KNOW a thirdgen that has gone 13.1 at 106mph with a zz4 and t56 on street tires, so with tires and perfect driving i bet a zz4 could push a thrid gren into the high high twelves
Old Aug 5, 2010 | 03:36 PM
metaluzc's Avatar
Re: ZZ4 Engine
Do you have any performance mods like headers, under drive pulley, exhaust? That spinning probably made you go from a 13.2/13.3 to a 13.7.
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
