How much HP would this make????
Old Aug 6, 2010 | 03:47 AM
JD4Bolt's Avatar
350 GM crate engine 4" bore
4 bolt main casting number 3970010
305 heads
RV mild cam
Edelbrock performer 2101 intake
Dynomax ceramic headers
3" custom stainless exhaust
700R4 transmission
3500 stall torque
Shift kit
TBI injection
Give me your best guess!
Old Aug 6, 2010 | 05:28 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: How much HP would this make????
I'd wager about 250-275 BHP with an RV cam and those heads... you could do better, but not a bad upgrade if you're on a budged and that's what is available at a reasonable price
Old Aug 6, 2010 | 05:31 AM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
Personally think thats WAY too much stall for the cam. Thinking like 1500-2000 is all that'll be needed if that much.
Old Aug 6, 2010 | 08:58 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
230hp and lose the high stall. Way too much for that combo.
Old Aug 6, 2010 | 04:30 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The stall of that converter is way too high.
When you say RV cam do you mean the generic 204/214 cam? Are you committed to running that cam? You would do better with a slightly more aggressive cam designed for fuel injection. Since you are using the 2101 manifold I would assume they are early 305 heads and not the swirl port type. What type are they?
Old Aug 6, 2010 | 05:32 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
No where near enough
~Couch
Old Aug 6, 2010 | 05:45 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Not much w/ those heads, save up for something that breathes better, it'll be worth it...
Old Aug 6, 2010 | 07:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Be careful with 305 heads on a 350. The 58cc chambers will send CR to 11:1 with flat top pistons. To high for pump gas. So you need to use dish pistons. Aim for 9.5:1 on cast heads 10:1 on aluminum. Port the heads, go bigger on the cam and you could make 325hp. You may want to switch to the Performer RPM intake though if you want horsepower.
Old Aug 6, 2010 | 10:04 PM
NAASBC355's Avatar
Car: several
No you can make 11:1 work you just have to run octane booster in the summer, that is if you have a good chamber design. Like my 49cc darts. You need to unshroud the valves back to the 350 gasket line or just short there of, switch up to 1.94/1.50 (min.) valves clean the sharp corners off the chamber on the plug side after unshrouding the valves, chamber volume should be 62-64 depending on valve job, and how many it's had. Then you can run flat tops no problem. The rest of the combo is still all wrong though.
~Couch
Old Aug 6, 2010 | 10:30 PM
st.inez's Avatar
don't bother unless you are going to do the whole engine from front to back....you are better off throwing a 100 shot on a STOCK MOTOR.... cheap and if you do the research it is quite reliable>> just a thought.. thats alot of money for not alot of gain.. sounds like you are having fun and that is what counts
Old Aug 6, 2010 | 10:35 PM
NAASBC355's Avatar
Car: several
ya thats really the truth of it. I have a complete head shop in my garage so I could set up those heads for me in about 3 hours to just be killer, but for the regular car nut 305 heads are usually used for door stops, and wheel chauks
~Couch
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
