Dear god please help me...
Old Aug 10, 2010 | 02:39 PM
  #51
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: Dear god please help me...
yep, well the parking brake cable WAS loose and rubbing, im not sure yet if it fixed my whole problem but FINGERS CROSSED! i need to fiddle around with the parking brake cable a little more to get everything in link but the parking brake still does work and i really never use it.
sonjaab, Thank you for pointing the parking brake cable out and i apologize for kinda being an azz and jumping to an conclusion.
Old Aug 10, 2010 | 02:50 PM
  #52
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
I watched your video and you cant hear much of anything , the only thing i got from it is JACK STANDS YOU NEED JACK STANDS do not get under a car on just a jack AND NEVER get under a car that's running and in gear on just a jack too many people die every year because they don't wanna take the extra 2 min to put stands under a car. Ok back to your flywheel shimming will not help broke teeth it could acually make it worse , if indeed you are missing teeth the only fix i know of is a new flywheel that means the trans has to come out it's not an expensive part at all but the labor is a bitch.
Old Aug 10, 2010 | 03:30 PM
  #53
Engine: 305TPI
well apperantly, IT WAS THE FREAKIN PARKING BRAKE CABLE! i cant belive an little cable caused all this hassle lol. Thanks everyone though for all your suggestions.
This is actually sadily one of the best days in my life, first i fix the problem on my camaro and then.... I GET MY 2 FREE MUFFLERS! I won two hushpower mufflers and tried them on the camaro and WOW they sound really good, much cleaner, quiter, and smoother sounding then having no muffler...
Old Aug 10, 2010 | 10:44 PM
  #54
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Originally Posted by iroc stangs
what do you mean part or most of it? do you mean of the whole problem im having? are you meaning the driveshaft is crapped? sorry i dont quite get what you mean (im slow lol)
well im positive the noise isnt coming from the front and i alredy did the procedure of having the wheels in the air and the car in gear and their was no noise from the wheels.
also i hear and slight popping noise in the cat, is this an problem? the cat was replaced YEARS ago but the car barely had any miles after it was installed.
I see it's been taken care of!! Great!!
I was meaning the grinding noise you mentioned while driving.
So, fixing the cable took care of the noise you heard when starting too?
Old Aug 10, 2010 | 10:49 PM
  #55
///DAN///'s Avatar
Engine: 355 SBC
i'm glad you got it fixed i didn't mean to sound preachy but it is very important to be safe always use stands we want you to be around till your old like most of us are , too many people get hurt for no reason good luck kid you got a great first car.
Old Aug 15, 2010 | 01:33 AM
  #56
Engine: 305TPI
yep it took away all of it, but it came back BUT its because i just disconnected the line and thought it would stay, obvisouly not but i cannot for the life of me get the braking cable links set up back into one piece!
Old Aug 16, 2010 | 09:08 PM
  #57
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Thats to be expected. In order to reconnect the brake cables and get them back in place, you need to back off the adjusting nut to the very end of the threads. This should give you the slack you need to put everything back together. Be sure you have the cables routed correctly through all the little brackets so it doesnt drag again.
Old Aug 23, 2010 | 01:06 AM
  #58
Engine: 305TPI
thanks, i'll give it an shot tomorrow or sometime soon, its not an HUGE deal to be i just wanted to find out what it was initially.
Old Aug 23, 2010 | 01:13 PM
  #59
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Get some jackstands. Being under a car only supported by a jack will kill you eventually. I know it's been said already, but it bears repeating. Safety first!
snowflake
Oct 19, 2015 10:24 PM
ronscott80
Interior Parts Wanted
Oct 13, 2015 12:26 AM
bschmale66853
Sep 30, 2015 08:11 PM
InfinityShade
Sep 5, 2015 06:38 PM
soarestransam
Sep 1, 2015 04:00 PM
