smog removal
Old Aug 6, 2010 | 08:21 PM
firehawk1724's Avatar
smog removal
ok i have a 89 trans am 5.7 tpi i want to remove the smog system..its ugly we dont have DMV inspection in michigan i want to know the proper steps on removal and do i have to change or adjust any numbers in the ECM when removing the system so it doesnt run rich/lean?
Old Aug 6, 2010 | 09:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: smog removal
If it's serpentine belt system, https://www.thirdgen.org/serpentine
If V-belt, same thing - just remove the belt for the smog and ignore the new belt rerouting
Old Aug 7, 2010 | 07:23 AM
Re: smog removal
ok cool i got that..thanks but what about the removal of the stuff attached to the headers and all that crap...how do i go about removing and plugging off necessary vacuums and what not? thanks
Old Aug 7, 2010 | 01:47 PM
Car: 1992 RS
Engine: Carbed 350
Re: smog removal
There's a small tube comes off each manifold, there is a check valve at the top where they all meet on each side - remove the check valve and use a standard NPT cap from Lowes/Home Depot to cat it off.
There's a small tube from the cat up to the pass side - I cut mine off at the cat, crimped the end shut, and welded it sealed with the old propane torch and coat hanger style welding (torch melts coat hanger wire like solder).
The AIR pump has 2 bolts in the back that hold the plastic square valve (this piece looks like Princess Leah's head) to it.
That's about it.
Old Aug 7, 2010 | 06:30 PM
Re: smog removal
That's about it.
seems pretty simple...also i have no cat on my car so i wonder if that tube is still there? i have original headers to straight piple flowmasters on.. the pipe caps what size caps do i need to obtain? is it necessary for me to remove the pump? can i just buy a shorter or in this case i think longer belt
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
