Ticking Noise
Old Aug 6, 2010 | 09:21 PM
AKATDOG's Avatar
Car: 84 Z28
Ticking Noise
i recently installed some rocker arms, and a new rearend on my 84 Z28, at idle it seems fine, when i start driving as soon as i hit about 10mph you can hear a pretty loud ticking sound
could over tightening the rockers cause this noise only when driving and not when idle?
Old Aug 7, 2010 | 01:34 AM
AKATDOG's Avatar
Car: 84 Z28
Re: Ticking Noise
any ideas?
Old Aug 7, 2010 | 02:57 AM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
Re: Ticking Noise
no could be slight detonation if you installed a higher ratio rocker. try a higher octane gas next time you fill up. Are you sure it's not coming from the rear end?
~Couch
Old Aug 7, 2010 | 08:17 AM
AKATDOG's Avatar
Car: 84 Z28
Re: Ticking Noise
~Couch
there identical rockers...
im not sure, the noise starts as soon as i pass say 10mph so kinda hard to hear exactly where its coming from
Old Aug 7, 2010 | 10:12 AM
AKATDOG's Avatar
Car: 84 Z28
Re: Ticking Noise
ok i dont think its coming from the engine compartment, i did a whole rear suspension recently including the rearend and driveshaft, could the drivshaft cause this noise? and how can i make sure, Thanks.
Old Aug 7, 2010 | 10:17 AM
NAASBC355's Avatar
Car: several
Re: Ticking Noise
ya u joints can jack it up by the axle support the axle with jackstands put it in gear slide under, and listen should be easy to find
~Couch
Old Aug 7, 2010 | 10:55 AM
AKATDOG's Avatar
Car: 84 Z28
Re: Ticking Noise
ok, jacked it up, and im almost sure its coming from the transmission, what would cause this? it was fine before i did the rearend work...
Old Aug 7, 2010 | 02:17 PM
NAASBC355's Avatar
Car: several
Re: Ticking Noise
probably unrelated, check to make sure the flex plates bolts are tight, my freind had this issue with his 4L60 where someting broke in the trans. and made a real funny noise I'm trying to remember what that was exactly. The sun gear breaks all the time in those tranny's also the 4L60's, and the 700's. May be time for that dreaded rebuild. That is if the flex plate bolts arren't loose. They can make all kinds of funny sounds.
~Couch
Old Aug 7, 2010 | 04:41 PM
AKATDOG's Avatar
Car: 84 Z28
Re: Ticking Noise
~Couch
thanks, the trans was rebuilt not even 10000miles ago, i will remove the cover later today and check the flywheel bolts, any other thoughts are welcomed...
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
