89 iroc hard to crank when hot
Old Aug 7, 2010 | 08:01 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
i bought this car a few months ago and its always been hard to crank back when its hot, the car has headers on it so im thinking it could be heat soak on the starter. what are some other things that can cause one to be hard to crank back when they are hot? (it turns fast like its not getting fuel, then luggs out, you can come back 30 minutes later and cranks like a brand new one)
Old Aug 7, 2010 | 08:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 89 iroc hard to crank when hot
Might try the ICM in the distributor - mine went bad and wouldn't crank when it was hot. If it was your starter and heat soak, the starter wouldn't want to turn or it would turn slowly.
Old Aug 7, 2010 | 10:39 PM
jamienoel's Avatar
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
Ooo! Way way back years ago, I found that the timing being all ***** made mine sound like the battery was going dead after a couple cranks, so it could be part of the electronic ignition system causing it.
More recently I thought I had a heat soak problem when it turned out to be a cracked starter housing, but that's because they were giving me the wrong one.
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 21, 2015 07:20 PM
mustangman65_79
Aug 11, 2015 03:17 PM
