what is this gasket...2.8 V6
Old Aug 9, 2010 | 04:39 PM
Heavy_Chevy's Avatar
i've been putting together this engine and i noticed i had some gaskets left over...it was a rebuild kit that i got but the guy just did the top end so idk what these gaskest are but they come in the intake pack. i attched a pic the ones i'm asking about are circled...obviously. any help appreciated.. i know what the intake and valve cover gaskets are and one is the t-stat housing. any thoughts on all the other gaskets is nice too. thanks in advance.
Old Aug 9, 2010 | 05:17 PM
zuurik's Avatar
Car: 1984 Trans Am replica
Engine: LG4 305 Carb.
Transmission: TH700R4
Axle/Gears: V6 rear-end
Re: what is this gasket...2.8 V6
Looks like the ones that goes between the two pieces of the manifold. Don't know why there are 4 of them..maybe the gaskets changed sometime.
Old Aug 9, 2010 | 06:56 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
yup upper plenum gaskets
~Couch
Old Aug 9, 2010 | 08:28 PM
well that's what i thought i thought it came with 2 sets for some reason...but i noticed that there are 3 holes in one of them and 4 holes in the other 3...ya see what i'm saying...Can anyone point out what the others go to?
Old Aug 9, 2010 | 08:59 PM
zuurik's Avatar
Check wich one will fit on to your manifold. When i had 2.8 then i noticed that it looked outside like it had 4 runners, but when i lifted the upper piece, it only had 3 on one side or somthing, dont remember exactly, it was 2 years ago..Anyway, I think this gasket kit came for v6 engines that were used. So maybe there is like manifold differences between 2.8 and 3.4 or 3.1 engines
Old Aug 9, 2010 | 09:54 PM
that would make sense but i got it in a rebuild kit for a 2.8. i have just not been able to figure it out so i have some gaskets just sitting around that i have no clue what they go to. and since the car isn't running right i was thinking maybe it coould be one of these gaskets not being on and it messing things up..
Old Aug 9, 2010 | 10:01 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
The extras are for the FWD V6 engines I believe.
Old Aug 9, 2010 | 10:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
In that pack, which I'm assuming is the FelPro MS93020, you need the 2 small gaskets, the tube of RTV, the 4 gaskets on the bottom, and the 4 in the top left corner. The round one with the corner on it is for the 3.1, and the other is for a different version of the 2.8 (the ones right above the gaskets on the right side of your circle). The 2 gaskets on the right in your circled area are for the upper plenum on the FWD MFI engines. You NEED the ones on the left installed between the upper and lower plenums, or you'll have a vacuum leak.
Old Aug 9, 2010 | 10:42 PM
must have just been easier to package them all together than to take time to only put the needed ones in it...i did put the ones on the intake for the upper to lower intake but i have so many pieces left it's crazy. i just didn't know what all the extras was for...thought maybe the guy before me didn't put something on...making it run like poo.
Old Aug 9, 2010 | 10:44 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's a universal MFI 60* V6 kit... Covers all engines between 85 and 95 (except the 3100) that don't have TBI injection (S10 and Lumina APV). So it has the extra gaskets. Too bad it doesn't have the later style EGR valve gasket in it, though.
