v belt routing diagram
Old Aug 10, 2010 | 11:47 PM
vleigh's Avatar
Could any one please help me with getting a diagram on the v belt routing for a 84 2.8 v6 engine. i bought a 84 camaro and I think some of the belts are missing. Any info would be appreciated.
Old Aug 11, 2010 | 06:32 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: v belt routing diagram
Does your crank pully have 1, 2, or 3 grooves? Basically, do you have A/C and a smog pump?
Old Aug 11, 2010 | 10:51 AM
vleigh's Avatar
I have the a/c but I have to put a new smog pump on it
Old Aug 11, 2010 | 03:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm looking in my Haynes - no real pic of belt routing ... but looks like ...
starting at groove on the crank CLOSEST to the timing cover...
1) belt from crank, to water pump, to A/C, to crank
2) belt from water pump to power steering to crank to water pump
3) belt from crank to water pump to alt to crank
4) belt from crank to water pump to alt to smog pump to crank
All have their own grooves, so there are 4 grooves in crank pulley, 4 grooves in water pump pulley, 2 grooves in alt pulley, 1 groove in a/c pulley, 1 groove in smog pump pulley.
That sound right? Do your pulley's have the above number of grooves in them?
Hope that helps!
Old Aug 11, 2010 | 03:06 PM
vleigh's Avatar
Thanks alot, that does help
Old Aug 11, 2010 | 08:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Hope that helps!
LOL exactly the reason why I swapped over to a serpentine set up.
InfernalVortex
Apr 20, 2021 11:31 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
kitt23
Sep 26, 2015 07:48 PM
