87 TPI MAF/And Code 42 info
Old Aug 11, 2010 | 07:34 AM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Can a MAF be bad even if the code don't come up,and can it screw with the idling of car??? I sucked in some water threw mine,it put 33 code up..But the next day,it didn't show code again.It's been a week and still no code..Any way to check to see if it's working correctly.I have a scanner tool too.Also,code 42 (electronic Spark Monitor) is in the system.I have unplugged the timing connnecter several times to set base idling..Is that causing the code to come up??
specialized
Jun 18, 2022 09:26 AM
GouldyGTR
Aug 21, 2015 10:43 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
