Compressor clutch plate
Old Aug 11, 2010 | 09:08 PM
joshwilson3's Avatar
89 Firebird. The Harrison is an R4, correct?
What are you guys using to hold the clutch plate so you can remove the nut? I rented a clutch plate holder from the local parts store, but it isn't correcty. But I may could get it to work to hold the triangle piece on the clutch. But would like a more correct way to do it.
And I believe the air gap is .020" and torque the nut to 10 ft/lbs?
Looking at replacing the clutch.
Old Aug 16, 2010 | 09:29 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Clutch And Such
Yes.
You need a clutch hub holder.
It looks like a spanner.
You can make one if no one has the right one.
Just cut a spanner out of metal plate and install 3 pins in it to grab the holes.
.02 to .04 are the limits so aim for .03.
10 ft/lbs?
Correct.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Aug 16, 2010 | 02:37 PM
Re: Clutch And Such
Thanks. But my clutch has no 3 holes which is why I couldn't figure out what to use. I have this:
Old Aug 16, 2010 | 03:34 PM
NINÅ's Avatar
Transmission: 765R4
Clutch And Such
This is what you need.
Available at CostPlusTools.com
Also makes a great jar opener in the pits.
Happy Racing!
Old Aug 16, 2010 | 04:19 PM
Re: Clutch And Such
Happy Racing!
Thanks.
Though are you sure that is correct? I looked it up and it says for V5 & DA6 compressors. I didn't see any mention of an R4 compressor.
Old Aug 17, 2010 | 01:00 PM
NINÅ's Avatar
Transmission: 765R4
Clutch And Such
V5, DA6, and R4 compressors all have the triangular flange allowing the tool to grip it.
Bring the photo and number to your parts store.
Maybe your store has a loan program so you won’t have to buy one.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Aug 17, 2010 | 02:11 PM
Re: Clutch And Such
Happy Racing!
Thanks, I'll check it out. The pic I had posted is the one I rented. So, I think that is the only one to rent. I'll keep looking.
Old Aug 18, 2010 | 11:36 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: Clutch And Such
I have this and it works for me although it is definitely not "made" for that specific clutch
Keep the tangs on the hub holder loose, and align them into the spiral wound springs portion of the hub against the pins that are used to hold it in place. Tighten them, and have at it.
It's awkward to get it to fit correctly, but once it is on, it works pretty good.
Old Aug 18, 2010 | 03:36 PM
Re: Clutch And Such
What I was thinking was adjusting those pins tightly to the outside of the 3 sides of the triangle piece. I think when I was messing with it, I flipping it over so the screw part was facing the clutch. I plan on trying that when I get around to messing with it.
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
