arching plug at night
Old Aug 13, 2010 | 06:12 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
heres the deal, Last night I replaced my radiator, I started the car and noticed a spark plug wire arching, I can see the spark right through one of the wires on the left side facing the car, I could also hear a very small ticking notices that comes and goes... sounds like a rocker arm to me... would this cause the spark wire to arc??....wires and plugs are brand new professionally done.
Old Aug 13, 2010 | 07:14 AM
Damon's Avatar
Re: arching plug at night
If it's arcing the plug wire is bad, period. Sometimes you get a bad one right out of the box. Often times there is a single strand of cunductor that doesn't get clipped properly and hangs out the union between the wire and the plug bood, arcing occasionally to the nearest ground.
The clicking you're hearing is the spark jumping that gap to the engine block/exhaust manifold or whatever ground happens to be nearby.
Old Aug 13, 2010 | 08:54 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
spark will take the least resistance to ground path it can, which means you got some bad parts somewhere, if jumping out of the rubber insulator is easier then firing off the plug..........
New parts doesn't mean they are good parts.
Old Aug 13, 2010 | 07:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
all of the above . new OEM carbon core type plug wires are not created equal . they all start to de-grade from date of mfg. . how long were they stored/onthe shelf/in the store ??? more likely than not installation was not the problem . higher price wires like M.S.D. , Taylor , or Acell pay off in the long run . good luck .
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
