replacing engine mounts
Old Aug 14, 2010 | 03:10 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Has anyone here replaced the motor mounts in these vehicals. Im finding it very hard to remove the old mounts.
If anyone has any advise, it would be greatly appreciated.
Old Aug 14, 2010 | 08:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: replacing engine mounts
I prefer to remove the lower control arms, but I keep reading about other guys just cutting slots for their wrenches to pass through. You could drill, grind or torch the old bolts, then just use new bolts through the holes for alignment while welding, but if you go that route, either use Moroso solid mounts, or use polyurethane mounts and be extremely careful to not overheat them while welding.
Old Aug 15, 2010 | 11:24 AM
TNT_Z28's Avatar
how hard is it to remove the lower control arms
Old Aug 16, 2010 | 07:36 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It's a real bear of a job, but it is the correct thing to do.
Old Aug 17, 2010 | 12:13 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
The worst part is usually getting to the nuts on the inside. One good way is to heat an open end wrench and bend it as necessary to get it up in there. Then use tape to hold the nut in the wrench when you go to put them back on.
The other thing I have thought about is tack welding the nuts to the frame before you remove the bolts. This might work with a stick welder if you are careful not to weld the nut to the bolt.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
