Did I get a bad fuel pump?
Old Aug 14, 2010 | 07:16 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Recently my car stopped running, but would sparatically start with low fuel pressure, just enough to idle. I figured my fuel pump was going back so I replaced it. Everything seemed fine at first but after shutting it off after driving it for a few miles it wouldn't start... surprise.. no fuel pressure again... it will start breifly if I bang the pump with a mallet but died as soon as I revved it. Any ideas what else I should check before ripping the pump back out and replacing it again?
Old Aug 14, 2010 | 09:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Did I get a bad fuel pump?
Did you replace the fuel filter?
How do you 'bang the pump with a mallet' when it's inside the tank?
Old Aug 15, 2010 | 07:47 AM
89RsPower!'s Avatar
yeah, new filter, new strainer, I typed it quickly. I ment bang the tank. I'll probably be kicking myself for using a bosh pump..
Old Aug 15, 2010 | 11:53 AM
Car: 1992 RS
Engine: Carbed 350
Before I yanked the tank out again, I'd check the wiring. There's a plug just under the rear seat (forward of the tank) - see if your getting voltage there. And apply voltage there and see if you hear the pump running. Then backtrace the wiring - to the relay and see about it.
Old Aug 15, 2010 | 12:47 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I had 2 fuel pumps go bad on my blazer, one of them was within 2 weeks of installation, the other lasted 3 months. My sister-in-law had hers go out in 2 months. The brand was Airtex. If you bought that brand then I would not be surprised if it went out.
Airtex = junk!
Old Aug 15, 2010 | 02:17 PM
89RsPower!'s Avatar
does anyone have a wiring diagram incase it does end up being a wiring issue? I did check for power and ground before I replaced the old pump but im starting to wonder if it's an intermittant issue...
Old Aug 15, 2010 | 04:46 PM
Car: 1992 RS
Engine: Carbed 350
http://www.austinthirdgen.org/index.php?pid=19
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
