71 chevelle Tpi 350 swap bad ecu will v6 ecu work?
Old Aug 16, 2010 | 01:21 PM
71ChevelleSS's Avatar
Hey guys I had a bad turn of events. I have a 71 chevelle which I just completed my frame off on now working with engine and body and paint.
It has a 1987 firebird GTA 5.7 motor ecm and harness in it right now with a t5 trans.
My question is can I use a v6 ecm if I just swap the prom chip? From what I understand the v6 harnesses are pretty identical needing some changes and lengthening of wires to use on a v8.
My ecm is bad in the 87 and it is stil MAF so I am wondering about the v6 ecu swap cause I am sure my prom is good but bad board on the original ecm.
What about tbi computer? will a 88 5.7 tbi truck ecm work if I swap proms?
Please help as right now this is my only car!!! Thanks guys
Old Aug 16, 2010 | 05:52 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 71 chevelle Tpi 350 swap bad ecu will v6 ecu work?
yes,swap out the prom. on the v6 ecm
Old Aug 18, 2010 | 12:11 PM
Ok one more question. I have a 87 l98 prom can i still use that prom on the 90-92 v6 ecu? Or will I have to get a 90-92 v8 prom?
Please let me know asap.
Old Aug 18, 2010 | 01:39 PM
ninetyone's Avatar
Axle/Gears: 3:42
https://www.thirdgen.org/ecminterchange That is the prom interchange guide. The 165 ecm is for mass air vehicles and I believe the 7730 is speed density. Sounds like you have a 7730 (speed density) ecm and need to use the 165 (MAF) prom. https://www.thirdgen.org/forums/diy-...-question.html Also look at that link, that guy is trying to do the same thing you are.
Old Aug 18, 2010 | 01:42 PM
ninetyone's Avatar
Axle/Gears: 3:42
sales@tbichips.com Harris Performance. That guy also does TPI chips pretty cheap. You would send your prom (MAF) to him and then he would send you back a custom high performance chip with the proper adapters,etc.
Old Aug 20, 2010 | 05:31 PM
Nice! Thanks alot for all your help bud. I owe you a beer!
Old Aug 20, 2010 | 07:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm confused - how can a V6 prom run/control & have fuel/timing tables for 8 injectors and cylinders?
Old Aug 21, 2010 | 03:25 PM
ninetyone's Avatar
Axle/Gears: 3:42
It can't .
Old Aug 21, 2010 | 03:37 PM
Car: 1992 RS
Engine: Carbed 350
So I'm really confused then - the original question - isn't he asking if he can use a V6 prom on a V8 ECM board?
Old Aug 21, 2010 | 04:24 PM
ninetyone's Avatar
Axle/Gears: 3:42
I think he wants to know if he can just use the v6 emc and the v8 prom together,which I believe you can, however his situation is this: His engine and original ecm are MAF. So , he is basically asking if he can use his MAF prom with the speed density ecm. The 7730 ecms were speed density 1990-92 and the 165 ecms were MAF 87-89 if i am correct.
Bubbajones_ya
Jul 6, 2024 08:32 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
gta892000
Sep 16, 2015 12:40 AM
Stryker412
Sep 7, 2015 09:11 AM
