Starting my first engine build, tips/advice?
Old Aug 17, 2010 | 01:18 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
so im building up my first engine for my iroc, ended up scoring a fulley machined 350 with the rotating asseble already installed and everything for a good price from a local engine shop. My plan and the parts ive got for it are a new comp roller cam, comp push rods and roller lifters, edelbrock pre assemble cylinder heads, scorpian roller rockers, holley stealth ram setup and more but i guess thats just the main stuff.
now im pretty nervous about building this thing but im thinking the hardest/most time consuming stuff is already done haveing the rotating assembly in and heads built right?
any tips or advice before i get crackin? be more worthwhile to just pay a shop to put it together for me?
Old Aug 17, 2010 | 01:37 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Starting my first engine build, tips/advice?
I say build it if you trust yourself. Its not hard at all. Even putting the rotating assmebly together is fairly easy.
I would buy a good torque wrench. Not a cheap no name one. This is for putting the heads on. I would also buy an adjustable pushrod. This is to make sure you get the correct length pushrods for your motor as they may need to be shorter or longer than factory.
Other than that just take it slow and ask questions if you need to. Its nice popping the hood and saying "I built that".
Old Aug 17, 2010 | 01:54 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
yea that what i want to be able to do lol, everyone i know just buys everything, no real appreciation for it
Old Aug 20, 2010 | 01:49 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
just wondering, but when im ready to pull the old engine out, do i have to get new longer bolts to put into the heads for the chain? or can i just back them off enough to get the chain and washers in there? also i got one of those engine balancers that has 4 points to it i guess you would call it, instead of one in the driver side front and one in the pass side rear would i do one in each corner?
thanks
Old Aug 20, 2010 | 02:19 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Most likely you'll need longer bolts; be sure to get Grade 8; others may bend.
I've always used a two-point attachment when pulling an engine. Depending on the clearances, I sometimes went with passengers front/driver's rear and other times driver's front/passenger rear. Depends on how easy it'll be to attach and remove the bolts.
Make sure you use thick washers on the chain bolts so the heads of the bolts won't pull through the chain allowing the engine to drop - That's not good.
How confident are you that you can do this project?
Jake
Terrell351
Jun 13, 2021 01:13 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
