new SRP or USED JE Extreme ?? HELP!
This friday i need to purchase my pistons, im building a turbo 355 LT1 with boost retard now i have 2 choices
NEW SRP pistons with new JE rings $600
mild turbo application
or
Used JE Extreme Duty Pistons with used rings $600
less than 1000 miles no dings nothing look like new
will i need new rings ??
same price one is new other is used, different strength, WHAT TO DO??? HELLLPP?? ANYONE PLEASE what would you pick
or
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: new SRP or USED JE Extreme ?? HELP!
You should always use new rings.
The JE pistons are a better quality than SRP. They're probably also lighter.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
well if u know for sure the used pistons are good and have no crackes they are the stronger of the two,
i would go new i like it shiny and look in to new rings cost. thats another 150$ on top.
ive never seen a srp piston come apart so i have nothing to say bad about them.
Car: 87 IROC L98
Yes they do but as I already mentioned, the JE pistons are a better quality and are lighter than SRP.
Yes JE makes SRP but pistons under the JE brand are made with better alloy than the SRP's, i was told 12 psi maxs for SRPS and then 20 psi for the JE's
I have a new issue now which i can really need the help https://www.thirdgen.org/forums/tech...e-pistons.html
Thanks to everyone
Thanks to everyone
buckeyecelt
Sep 24, 2015 05:50 AM
