Lock cylinder doesn't turn all the way
Car: 1986 Camaro I-ROC Z28
Engine: 400
Transmission: R700
Have a 1986 Camaro I-ROC Z28. never had a problem turning it on but now the lock cylinder doesn't turn all the way. It does turn to on but when I try to turn it to the section where the starter kick in it stops. I have read a lot of other cylinder issue but not one like mine. I'm guessing I will have to replace the lock cylinder... I'm I correct?
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Lock cylinder doesn't turn all the way
You probably need a new cylinder. One thing to ponder; I had a problem with a warn out key. I would just for the heck of it try your spare or original key and see if your problem is still there.
Engine: 400
Transmission: R700
Thanks. I went ahead and took it all apart. I have the cylinder in hand and it stops before turning all the way. I will install the new cylinder tomorrow. Hope this takes care of it.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
