blown head gasket or not?
Old Aug 26, 2010 | 07:20 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
ok I started my car yesterday and there was steam coming from the exhaust. It was 80 something degrees out side so I'm guessing I have a blown head gasket. But the question is ... Is there any possible way coolant could get into the combustion chambers due to a bad intake? or intake gaskets? The intake I have is a transplant from a TA and I was just wondering if it could be the problem?
Old Aug 27, 2010 | 09:36 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: blown head gasket or not?
Sure can, have you checked your oil yet? Is it milky? How's the coolant level?
Old Aug 30, 2010 | 12:46 PM
Engine: 350 for now
Transmission: wc t5
the oil is ok. but i took the intake and heads off yesterday and one of the middle bolts on the drivers side of the intake had oil all over it? and i couldnt find a smoking gun that pin pointed the coolant burning out the tailpipe.
Old Aug 30, 2010 | 01:18 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
They got these pressure tests at autozone for bout 30 bucks with the solution... try that, outher signs are air bubble in coolant..oil in coolant...coolant in oil..smoky engine..smoky exaust, I have also heard if u hold a piece of dry paper in front of the exaust and u get a bunch of wet marks it could be blown head gasket, O btw be careful with that pressure test kit too...it blew up in my face and brnt me good
Old Aug 30, 2010 | 02:50 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
When doing a pressure test, pressurize the system no higher than 20 psi.
Jake
Old Aug 30, 2010 | 10:09 PM
BahN's Avatar
Car: 1987 Trans AM
The oil on the intake bolt shouldn't be an issue as the bolts do hang into the lifter valley, hence why you always want to coat them in black rvt.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
