Repair manual perference.
Old Aug 30, 2010 | 05:25 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
for an 86 Iroc-Z. I'm looking for one that has good schematics. I have the 86 Camaro shop manual, but I'm looking for something better. I hope there is one.
Old Aug 30, 2010 | 05:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Repair manual perference.
There isn't anything better than the factory service manual.
Old Aug 30, 2010 | 05:55 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Which shop manual? Mitchells, Chiltons or the GM one you'd get from Helmsinc.com?
Please don't say it's a Haynes manual.
Old Aug 30, 2010 | 08:07 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Re: Repair manual preference.
If I did this right there will be a .jpg attatched.
Old Aug 30, 2010 | 08:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You've got as good as it gets, you just need the Electrical Diagnosis Supplement
Old Aug 30, 2010 | 08:16 PM
Scorpner's Avatar
Engine: V6, V8
Looks like that's it. I see the number in the lower RH corner.
It should have plenty of electrical (and vacuum) diagrams in the back.
Edit: Good call on the supplement.
From the Helms website:
1986 Camaro Shop Manual
Price: $75.00
In Stock
Qty:
Pkg Qty: 1
Media: Paper
Language: English
Item/Part #: ST36886
Old Aug 30, 2010 | 08:29 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
I'd settle for the electronic supplement. Some idiot is replacing his stock ECM with a BS3 and can't get the fuel pump to prime like it used to. Also, the same idiot may have damaged one of the two prongs on the no oil pressure cut off, but he thinks it should still prime the system regardless if the switch is bad or not. Could he be wrong? If he is, how do you bypass that switch, with a paperclip to test it? (BTW - it does crank.)
Old Aug 30, 2010 | 08:30 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Yep, that's the number.
Old Aug 30, 2010 | 08:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The switch is a backup for the fuel pump relay, it's not a "no oil cutoff. In a correctly working car, the switch isn't needed at all.
Old Aug 30, 2010 | 08:44 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Sorry it's sideways.
Any way to jump the relay to check it?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
