Whats holding me back?
Old Aug 30, 2010 | 10:13 PM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
what is holding my car back, i have a 1992 camaro t5 3.42 gears,
i had a 305 bored .040 over dished pistons, with the 2031 crane cam. everything else stock still had smog (no cats) and everything, ran a 14.6 at high elevation. dont know horse power.
well now i have a 350 .040 over flat top pistons, 193 stock chevy heads, same 2031 cam, headers, no smog,no cats, underdrive pulleys, tpi foil. have not ran it yet, dont know horse power.
i have read somewere sense i have a b4c i have 21lbs injecters, dont know if that is true.
it doesnt feel any faster then it was, feels slower and with the headers (hedman) its alot quieter then it was.
any ideas,
Old Aug 30, 2010 | 10:26 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: Whats holding me back?
Well, those heads are 64cc chambers, the swirl ports limit breathing to where they are limited to about 3.500-4,000 max. rpm. I'd check around at the boneyards for some vortecs. Problem is heads.
Peak numbers, stock heads:
178 cfm intake
146 cfm exhaust
Old Aug 31, 2010 | 11:38 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
thank you, i have a set of vortecs now i'm just going to get them rebuilt. do u think my tuned port is okay or should i replace the tb or the injectors?
and do u know if they sell any other vortec bases for the tuned port i can only find the edelbrock one. for 450$
Old Aug 31, 2010 | 12:00 PM
BahN's Avatar
Car: 1987 Trans AM
Well for figuring the size of injectors you need, we'll first have to calculate a ROUGH hp number. These simple formulas will not take in consideration of heads, cam, rockers, etc.
350ci x 5500rpm / 3456 = 557cfm
14.7 atmospheric pressure x 557cfm x 29 / 10.73 x (80F + 460) = 41lb/min
41lb/min x 10 = 410 ROUGH flywheel hp.
now that we have a ROUGH hp number, we can calculate the size of injectors needed.
Injector Flow Rate (lb/hr) = Horsepower x BSFC (we'll use 0.5) / Number of Injectors x Duty Cycle (you never want to go above 85% for long)
So: 410 x .5 / 8 x .85 = 30lb/hr @ 40psi or 31.28lb/hr @ 43.5psi
To be on the safe side and give yourself room to mod I'd get a set of 32-34lb/hr injectors @ 43.5psi and a good tune.
As for a TPI base: http://sdparts.com/details/scoggin-d...-center/sd3816 = $399
You will 100% need a tune after this but it'll wake that bad boy up.
As for the throttle body, the stock 48mm can flow ~700cfm. And if we take our simple ROUGH formulas:
14.7 atmospheric pressure x 700cfm x 29 / 10.73 x (80F + 460) = 51lb/min
51lb/min x 10 = 510 ROUGH flywheel hp.
I wouldn't waste money on a 58mm TB until you get a bigger cam in there.
Old Aug 31, 2010 | 03:02 PM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
thanks for all this i will have to remember it.
i was thinking around 26lbs injectors u really think that big, 32-34lbs injectors.
it sounds to me u know more about this than i do.
Old Aug 31, 2010 | 11:19 PM
BahN's Avatar
Car: 1987 Trans AM
It's all theory, and those numbers are under ideal conditions with no restrictions. As you stand now with those heads, yes 26's would be plenty. But with your vortecs and running 32-34#'s would allow for a decent amount of modding to still be done for future upgrades. But at the same time wont be a big issue to tune in for minimal mpg loss.
Old Sep 1, 2010 | 09:14 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
i guess my computer will only give it what it needs anyways. sounds good thanks man
Old Sep 1, 2010 | 09:18 AM
BahN's Avatar
Car: 1987 Trans AM
You'll want to have the ECM tuned for a big change like that 21 to 26 or 21 to 32. It's only one parameter that needs changed.
Old Sep 16, 2010 | 09:43 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
so what do u think about vortec heads, holley stealth ram intake, 32-34lbs injectors and lt4 hot cam? and custom tune.
or should i do differant intake or differant cam,
i can do the hsr intake for the same price for the vortec tpi base.
thanks
Old Sep 16, 2010 | 10:27 AM
InjectorsPlus's Avatar
Former Sponsor
You're running out of injector....and yes the heads.
If you do that and lean out, you'll fry the motor.
Old Sep 16, 2010 | 10:57 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
so i will want more injector, what size do u think i will need?
Old Sep 16, 2010 | 11:02 AM
Former Sponsor
If you're at 510 HP as the estimate above shows, you're into about 36s.
Old Sep 16, 2010 | 11:49 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
you ment 410 right, lol okay i will get 36s.
thanks
Old Sep 16, 2010 | 11:51 AM
Former Sponsor
thanks
OOPS sorry, typo.
Old Sep 17, 2010 | 10:20 AM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
with this set-up what do you think my rear wheel horse power will be, and what do u think my 1/4 mile time will be, 3,42 gears and a t-5 at high utah elevation,
i know i will have to upgrede my rear end and tranny after all this.
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
johanlindgren
Aug 16, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
