Settle a disagreement
Old Sep 4, 2010 | 08:54 PM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
I am swaping heads on my 305 with a set of new rebuilt heads, a friend of mine was over to check it out, When he was watching me he noticed that I wasnt keeping the pushrods in order to were they came from as well as the rockers. He said I am to keep them all in order I say no need they are going on a new set of heads, I have done this many many times just like this, just heads and I have never heard this or have I ever had a problem. I told him that the only thing you need to keep in order are the cam and lifters because the lifters are broken in to the cam lobes and that does matter. If you are going back with the same cam and lifters. I am not even taking them out.
Who is right?
Old Sep 4, 2010 | 09:11 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Settle a disagreement
I've heard to keep them in order, but I dont really see how it would matter. Its not like a cam lobe where there would be a wear pattern. Its just a rod that pushes on something. I know a bunch of people that have taken motors apart and didnt keep the rockers or pushrods in order and had no problems.
Old Sep 4, 2010 | 09:24 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
30 years of rebuilding I have never done it or heard of it til now. But I'm sure some people are OCD
kd5icr's Avatar
Axle/Gears: Stock
Well I dont have 30 years but I have about 20. And Thats what I am saying. The rockers and pushrods dont have a pattern like cams and lifters do.
Old Sep 4, 2010 | 09:35 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Ive heard to keep them in order
Old Sep 4, 2010 | 09:56 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
it can't hurt
Old Sep 5, 2010 | 09:55 AM
kd5icr's Avatar
Axle/Gears: Stock
Originally Posted by FNFAL308
it can't hurt
To late for that. I am putting on a new set of heads, and I was thinking of putting on a set of roller tip rockers if I can get them for well under 100 dollars. I know it cant hurt but I have never had a problem before. And like many people do I go with what you know.
Old Sep 5, 2010 | 07:24 PM
triggerman454's Avatar
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
New cam and lifters.....new push rods and rockers arm kits.Also check the guide plates for wear...PERIOD I M humble O .
Old Sep 5, 2010 | 08:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If pushrod order mattered, then you couldn't replace just one that got bent - and we've all done that.
Old Sep 5, 2010 | 08:28 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I've only been told if lifters are pulled & re- used on the same cam
that's hydrolic, then they have to go in the same spot & ride the same
lobe, but with rollers, it doesn't matter as long as the rods are the
same length & the lobes are the same. But if the cam is bigger, then rod
length has to be checked.
Never heard anything about rockers.
Old Sep 5, 2010 | 08:41 PM
kd5icr's Avatar
Axle/Gears: Stock
Oh yeah for sure there, but this is just a head change out.
87v6Bird
Jul 1, 2018 04:12 PM
bbsr72
Apr 2, 2016 09:12 AM
LittleFranks
Oct 7, 2015 11:26 PM
Chevykid810
Sep 28, 2015 12:57 PM
HikoriYami
Sep 21, 2015 07:11 PM
