Cant get car to start after putring in new cam
Old Sep 5, 2010 | 07:55 PM
donmeca007's Avatar
Car: 1985 Z/28
Engine: Dual carbed 357
Transmission: 5 speed
I have a 1985 z-28, I am running a 350 bored.40 over. 1.60-2.02 heads, vodoo cam .507/.507 at 106 deg lube and dual card setup. I put new cam in and lined the dots up on my gear drive dot to dot when my #1 was top dead center. And now when i try to start it it just back fires and blow gas out the carbs. I checked #1 piston and made sure #1 plug were same. I also pulled timeing back off and now my dots are off. crank is at top and cam is at top now. ???????? I dont know how to deg. a cam is that my problem or am i over looking something??????
Old Sep 5, 2010 | 08:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cant get car to start after putring in new cam
Where was the distributor when it was lined up dot-to-dot?
Old Sep 5, 2010 | 08:13 PM
donmeca007's Avatar
Car: 1985 Z/28
it was 180 out so i pulled it and turned it 180 back to @1 and still no fire just back fire???
Old Sep 5, 2010 | 08:16 PM
donmeca007's Avatar
Car: 1985 Z/28
have done cam replacements before and never ran into this problem. the cam is by lunati#07102
Old Sep 5, 2010 | 08:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You lined the rotor up with the #1 terminal when the timing set was dot-to-dot?
Old Sep 5, 2010 | 08:43 PM
donmeca007's Avatar
Car: 1985 Z/28
yes i did that, and when i tryed to start it it just back fired I tryed adv. and ret. the dist. nothing. and then i pulled the timing cover off again when #1 was top dead and the timing mark are now off. I dont understand???????
Old Sep 5, 2010 | 08:47 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
This is could be normal. The cam spins at exactly half the speed of the crank. This means that if you spin the crank over one full time, the crank dot will be back where it started, but the cam will only have moved one half turn.
Sounds like the timing is off. It doesnt matter if the rotor faces number 1 clyinder. You can have it pointing where ever you want. Just pull number 1 plug and spin the motor over by hand till you feel air being PUSHED out. Now line the mark on the balancer up with the timing tab on the timing chain cover. Then when you put the cap back on, remember where the rotor was and put your number 1 plug there. You can also use a timing light to see how far off it is. If it doesnt start, try moving the distributor around a little to see if it helps.
Old Sep 5, 2010 | 08:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At dot-to-dot the rotor needs to point to the #6 terminal.
Old Sep 5, 2010 | 09:04 PM
built91Z28's Avatar
I have number 1 cylinder on the cap facing cylinder 2. The distributor doesnt know what cylinder its firing. So long as the cap is lined up correctly with the rotor.
donmeca007's Avatar
Car: 1985 Z/28
ok ty I will try that in the morning!!
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
