What size of valves should i have on a 350
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Okay so what size of valves should I have in the cylinder heads for a 350. I am planning on putting a 350 in my trans am and am going to put aftermarket heads, cam, and headers on.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: What size of valves should i have on a 350
Standard size valves for aftermarket heads is 2.02 intake and 1.6 exhaust.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 2.05 intake can be used but I doubt you're anywhere near a power level where the even larger intake is necessary.
Well I already have a flowpro muffler a eldebrock intake and carb for a 350, with a cam, headers and cylinder heads it should be around 380 - 400 horse.
Car: 87 IROC L98
2.02/1.6
The smaller vavles are for a 305. No reason to build a 350 and put stock sized small valved heads on it.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Stock 305 valves are 1.84/1.5
Stock 350 valves are 1.94/1.5
That's what he said above "stock".
Standard aftermarket 350 valves are 2.02/1.6 This is the norm, and is fine.
Agreed. 2.02/1.60 is typical for aftermarket 350 performance heads and works just fine on most applications.
ADDING bigger valves to stock heads, however, is a dicey proposition. Usually not worth the effort or expense vs. just buying aftermarket heads.
What heads are you considering buying?
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
