Tapping Issue
Old Sep 5, 2010 | 01:57 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Tapping Issue
I installed a umi box sub-frame connectors (welded) an at first going into reverse the exhaust pipe taped it an when in drive it'll go away. now after a few monthes when in reverse no sound nor drive, then another month later still no tapping in reverse but in drive from a stop then go from 2.5k+ it'll tap (I think..) so i checked under the car and the exhaust pipe to the tranny (the hanger) was rotted so i replaced it and bent it down a bit. Now when driving the tapping is very little but i can still hear it. I checked under the car and the distance from it is pretty big i think maybe an .5"+ or so.. so i don't know if thats really what the tapping is or something else. My car has a 700r4, stock exhaust size, its a 305v8tbi. I'd like some help trying to figure this out. Also is there a type of rubber block or something i can squeeze between the exhaust pipe on the passenger side thats close to the subframe connector? I don't know of any material that can withstand 500+ degrees F.
thanks,
timinsk
Old Sep 12, 2010 | 06:26 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Tapping Issue
Old Sep 14, 2010 | 05:11 AM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Re: Tapping Issue
Hey I would get the exhaust as tight as you can but this dont make since from what you did to the car but check all the exhaust mounts make sure theres very little room on them... My 86 right now the passenger one taps when im turning still need to fix that but the person who had the car before me had a gravel road that it use to bottom out on so that's why mine is tapping...
Old Sep 14, 2010 | 07:51 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Tapping Issue
i'll try tightening all the bolts... i tried wiggling the exhaust an its way to stiff to budge.. i dont get whats tapping. i even had my buddy drive as i sit in the passenger seat. on the camaro theres that big dip in the foot place, right there i feel the tapping..
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
dimented24x7
Sep 6, 2015 03:51 PM
