cant pass inspection.
Old Sep 7, 2010 | 12:44 AM
camarocharlie92's Avatar
Car: 92 Camaro RS 25th Anniv. Edition
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 3.27 posi
im trying to pass inspection, my HCC levels and O2 levels are quite high.
ive done a full tune up (plugs,wires,cap,rotor, O2 sensor) and intake manifold gasket. i havent changed the cat yet. im just not sure what else i can do.
im also running a little rich. how can i stop this from happening?
any tips or tricks i can do to get me to pass?
thanks guys!
Old Sep 7, 2010 | 06:00 AM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: cant pass inspection.
This is more than likely caused by by ignition misfires.
Old Sep 7, 2010 | 04:55 PM
Engine: 305 TBI
ok, gonna try and trace a misfire. anything else it might be?
Old Sep 7, 2010 | 04:57 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
every day I'm reminded how much I love PA's "visual only" inspection on my 89.
Lean out the fuel mixture if it's running rich.. this can be done a number of ways.. one of which is isopropyl in the gas tank. But you didn't hear it from me. *wink*
Old Sep 7, 2010 | 08:08 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Elmwood park huh? I'm from Haledon the other side of Paterson lol I got around emissions by putting a full msd in my camaro it dropped my emissions by half the standard
Old Sep 7, 2010 | 10:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A quart of methanol, methyl alcohol or whatever names you want to call it into a full tank of fuel. Use a higher octane fuel to reduce any spark knock that might be detected by the knock sensor which will cause the ECM to retard the timing.
195 thermostat and make sure the engine is hot when tested.
Set the timing to factory specs.
New air filter
Working EGR and PCV system
Old Sep 11, 2010 | 01:05 AM
Engine: 305 TBI
thanks for all the tips guys! really appreciate the help. hope i don't sound dumb by asking all these questions. just trying to get as much advice as i can, and trying to learn more about the car as i go along.
where can i get methanol? i know i sell isopropyl at my parts store. is it the same or different?
all parts changed so far have been ac delco. figured it would be the best thing. that shouldn't have anything to do with it right?
Old Sep 11, 2010 | 01:07 AM
Engine: 305 TBI
kool stuff, not too far away. u should come out to my friends meet up at pizza 46 in little falls ( kohls shopping center) its thursday nites at 9
Old Sep 11, 2010 | 09:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Home Depot etc. Normally called Methyl Alcohol. Also can be used as a gas line antifreeze in winter but for that, you only want a cup full per tank of fuel.
Old Sep 13, 2010 | 10:04 PM
Engine: 305 TBI
reporting back:
i replaced the coolant temp sensor, put some methanol in the gas tank, then filled up with 93. seems to be running better. but now im getting a few drops of water out of the tail pipes. not sure what it is. i checked the air pump and its working properly. anymore tips for me?
thanks guys. all your help is appriciated.
Old Sep 14, 2010 | 02:26 AM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Hey haha love having an 86 no more inspection! run sea foam thru your intake you will have to find a vaccum line that will run it thru the whole intake or get it into the throttle body the stuff is high on price but i can bet you will pass!
- Get the sea foam in the intake
- Have someone hold the car at about 1500 to 2000 RPMs (it will tey to shut off)
- So it until most the smoke is gone
- Shunt the car off and sit for about 20 mins
- Take car for drive and have it re - tested
Old Sep 15, 2010 | 11:52 PM
Engine: 305 TBI
i wish, in NJ car hasta be 25 years old for no inspection/ historic plates
local advance auto has it for 8 bux, my friend told me to try that. but im sketchy on using it, i dont wana ruin anything.
Old Sep 16, 2010 | 12:20 AM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
High HCC and O2 levels are normally caused by ignition misfires. I recommend finding the root cause of this and repair what is wrong instead of trying numerous tricks to get it to pass inspection. If you don't care about your car running the way it is supposed to, disregard this post.
Lbibb
May 5, 2016 12:00 AM
darwinprice
17
Oct 11, 2015 11:51 PM
