bets way to set litfers after replacing cam
Old 09-07-2010, 04:43 PM
donmeca007's Avatar
Car: 1985 Z/28
Engine: Dual carbed 357
Transmission: 5 speed
Yes I just put in a new cam and cant get my car to start was thinking it was a timing thing but have tried everything to get timing right. Now i think that maybe my lifters r not set correctly what is the best way to set my lifters. I running Hydraulic Flat Tappet cam.
Old 09-07-2010, 05:10 PM
randomname's Avatar
Car: 83 Z28
Re: bets way to set litfers after replacing cam
i seen your other post, You set the exhaust valve when the intake valve opens and has about half closed and the intake valve as the exhaust starts to open. What this does is insure that the valve is on the back side of the lobe opposite the ramp.If you set the valves properly one cylinder at a time you can go 1/4-1/4 turn past zero lash and you are set from now on.
Frozer!!!
01-19-2024 04:55 PM
specialized
06-18-2022 09:26 AM
camaro71633
09-01-2015 10:24 AM
1988iroc350tpi
08-14-2015 07:52 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: bets way to set litfers after replacing cam
