Washer won't work
Old Sep 8, 2010 | 01:39 PM
Spikey_Kiwi's Avatar
Car: 1986 Trans AM
Transmission: auto with Dual Gate Shifter
Washer won't work
Have an 86 TA with pump attached to wiper motor.
Wipers work fine but get no screen wash.
Think the issue is the pump as the tube seems to get no suction at all and cant hear anything other then the wiper motor when switch is held.
Don't know how loud sound should be though so may be not hearing it?
Any way to confirm/ fix this problem?
Waiting in hope guys
P.S. im in the uk so cant just pop into my local yard for parts and spares so would prefer a way to fix existing parts.
Old Sep 8, 2010 | 03:15 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Washer won't work
you could try having someone push the washer button inside the car and test the connector going into the pump to see if its getting voltage. if so, then you the pump's getting power and its bad
Old Sep 9, 2010 | 03:21 AM
Car: 1986 Trans AM
Aye tried and the pumps bad :S
Gone with the getto fix of strapping a temp pump next to the origional for the MOT (gov vehicle check) so i can get my pass then will sort later.
Thanks for the help though
Old Sep 9, 2010 | 07:13 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I believe in 88 they upgraded the pump setup, which also turned out to be more reliable than the pre-88 setup.
Would be the perfect time to upgrade.
Old Oct 3, 2010 | 06:17 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
What is all involved/needed to do the upgrade?
Old Oct 3, 2010 | 11:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The washer bottle has the pump integral to it, so its all one assembly. Youd need the bottle/pump assembly, new hoses, and mounting hardware. You will also need to re-run your pump power wiring to the washer bottle at the front of the engine compartment. Not too hard, but you will need to aquire the parts first, which may be easier said than done in the UK.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
fonzie85
Aug 13, 2015 11:50 AM
