Car won't start
Old Sep 8, 2010 | 08:00 PM
romeomeo's Avatar
Car won't start
92 camaro rs v6. when I turn the ignition I hear a click. at first it did this a couple times and then started. now it won't start at all. what's wrong?
Old Sep 8, 2010 | 08:53 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: Car won't start
Could be battery.
Old Sep 9, 2010 | 05:25 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Car won't start
What happens if you try to star it and then turn it off and then try to start it and keep doing that over and over real fast?
Old Sep 9, 2010 | 05:27 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Car won't start
My car has been doing that for over a year.LOL. I think my prob is the small purple wire from the starter to the neutral safety switch. Sometimes I have to get like ten clicks and then it starts!
Old Sep 9, 2010 | 08:35 PM
Car Lover's Avatar
Car: 1989 Firebird
Engine: 350 TBI
Transmission: 700R4 (Sadly)
Axle/Gears: ?.??
Re: Car won't start
Well make sure you have a good charged battery if you do then check out all your connection to your starter. Make sure its tight and even the grounds. I've had a loose ground that made my truck not start and all I ad to do was tighten it up.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
