heatercore hose question
Old Sep 9, 2010 | 09:36 PM
bikerboys29654's Avatar
ok i have a lb9 ive had some vacum line issues so in the process of pulling the intake off the heater valve broke. is there anyway of bypassing it? i dont plan on driving it in the cold weather im also taking the ac out of it. if been looking around for picures of people thats done it ive found none.
Old Sep 10, 2010 | 12:51 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: heatercore hose question
I took out my heater core as well when I removed my AC. I sold it after I took it out and then wished I didn't. I could tolerate the heat in the summer and the cold in the winter, but man when it rained...
To answer your question, I just took the two hoses off the firewall and connected them with a coupler and two clamps. I am pretty sure there is a better way but that is how I got it done.
Old Sep 10, 2010 | 01:12 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
You could also cap off the hose at the radiator that goes to your heater core and cap off or buy a plug to replace the fitting on the intake. That would get rid of all the hoses.
Or if you still want to be able to have heat, just get rid of the valve. Run one hose from the radiator to your heater core, and the other directly from the heater core to your intake.
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
