Timing Chain
Old Sep 14, 2010 | 10:25 PM
Bota 65's Avatar
Car: 1987 Formula
Transmission: 700 R4
Axle/Gears: 3.42 L/S
Timing Chain
Do I need to drop the pan in order to change my Timing Gears? I have been leaning toward yes, but I have a friend teeling me no. Any advice would be appreciated.
Old Sep 14, 2010 | 10:37 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: Timing Chain
No, the front seal will be destroyed and you will need to use some finnesse, so as to not distort the cover. When you are ready to install, the tabs in the corners of the front seal lip will need to be trimed. If you drop the pan, you will need enough room to clean up properly, which means removing the pan. The only way to get enough room to remove the pan is to jack up the block away from the K-member. Disconnecting the exhaust, unbolting the engine mount halves, loosening the trans mount, etc.........
Old Sep 14, 2010 | 11:13 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Timing Chain
usually do not have to drop the pan on 1975-85 SBC
i did not have to on my '82 and '84 engines-IIRC,
'86 up have a 1 piece molded rubber pan gasket
-on those you probably will have to lower the
pan,but might be able to leave the gasket in
place and reuse if it is still good
Old Sep 15, 2010 | 03:13 PM
Bota 65's Avatar
Car: 1987 Formula
Re: Timing Chain
Popped right off thanks guys.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
