Is there any way to check my compression?
Old Sep 15, 2010 | 11:36 AM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
I recently had a 350 late model roller motor for my 91 tpi and for some reason im only gettin 263 rwhp and 333 rwt and i have alot into this thing, lt4 hotcam, ported 083 heads with 2.02 1.60 valves, headers, throttle body, ported plenum, and the guy who tunned it said he did what he could without hurrtin the motor, and he acctualy asked me if it was a 5.0 block because it was not needing that much fuel and the horsepower and tourqe numbers reminded him of built 5.0 tpi`s and that i should be gettin alot better numbers. Any ideas on whats goin on here guys My only guess is that the guy who built my motor didnt put the right compression of piston in it because i asked hime to make it 9.7 to 1 but i think he made it like 8.5 to 1.<----- would this make my setup act that sluggish, and if so how could i check to make sure its 9.7 to 1 without taking the motor appart?
Old Sep 15, 2010 | 11:44 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Is there any way to check my compression?
To measure the compression ratio, you would have to know exactly what pistons are in it and what head gaskets were used.
Just go rent a compression tester from auto zone. If you know what cam you have, and you find out your cranking compression numbers, you can roughly find out what your compression ratio is.
I'm not extremely familar with the TPI numbers, but those dont sound that bad. Thats probably a little over 300 horse and 400 foot pounds at the motor.
Old Sep 15, 2010 | 12:03 PM
ok cool ill do that asap and post the numbers to see if there where they are suppose to be
Old Sep 15, 2010 | 01:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Do a compression test to see what the cranking compression numbers are. That will give you an idea where your at and what performance to expect. Check all the cylinders to get an idea how each one is performing.
How ported are the TPI components? Did you port the base too or is it aftermarket? Stock TPI?
Those numbers arent too bad if stock TPI. Really arent all that bad for ported stock TPI. Run it at the track and see what it traps, dont necessarily go by dyno numbers. Now if the heads are ported fairly well and the intake stuff is aftermarket, then I'd expect a bit higher hp numbers and torque.
Old Sep 15, 2010 | 01:34 PM
the base is stock the plenum ifs ported all the way for the 58mm throttle body, gonna do the compression test this evening hopefully the guy built it right and the dyno is just way off. Where should the compression range be for the 9.7 to 1 ratio?
Old Sep 15, 2010 | 03:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Not 100% sure but most limit pump gas at 200 psi cranking compression....your build is not pushing the limits there, so i'd expect in the 150-170 range. 9.7 to 1 on an iron head is fine, usually over 10 to 1 starts to get alittle picky and needs a slightly larger cam. hotcam isnt huge but isnt really small either, so in that range above makes sense to me.
I think i have a calculator back home i'll try with those cam specs and see what it estimates.
Old Sep 15, 2010 | 03:25 PM
cool i realy appreciate the help
Old Sep 16, 2010 | 12:11 AM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
150-170 range?
I just did my compression check and got inbetween 120-135 on all 8 cylinders
350, HSR, iron vortec heads, 268 cam.
My car also only made 246rwhp and 279rwt on a dyno tune.
Old Sep 16, 2010 | 01:04 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you can get access to a bore scope (a little camera on a 'snake' that goes through the spark plug hole) you can see the piston. A good machine shop may have one. That, along with knowing what heads you have by casting number, should give you an idea of what the CR is. Its the most accurate method short of removing the heads.
Old Sep 16, 2010 | 06:20 AM
InjectorsPlus's Avatar
Former Sponsor
If this is a stock TPI motor with:
1. fairly mild Cam
2. Mild head porting
3. Mild manifold porting
I don't see how those numbers are so out of line.
The throttle body is useless and didn't gain you anything.
Those numbers don't sound that far off...
Old Sep 16, 2010 | 07:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Originally Posted by 86camaroZ
150-170 range?
whats your static compression?
I just did a quick calc and I got 156 psi for the OP's hotcam motor above at 9.7 to 1 compression, at 150 rpm starter crank speed.
Old Sep 16, 2010 | 10:45 AM
86camaroZ's Avatar
Car: 86 iroc
Axle/Gears: 370
Static compression, when the engine is being turned by the starter, is right around 120-135psi on each cylinder.
Old Sep 16, 2010 | 11:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I mean whats your static compression ratio? 9 to 1, 9.5 to 1? etc...
120-135 would usually mean less than optimal ring seal but these are just estimations/calculations.
Old Sep 16, 2010 | 11:29 AM
built91Z28's Avatar
Did you have the throttle open while doing the compression check? I've heard it can make a difference.
Old Sep 16, 2010 | 12:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
engine should be warm too
Old Sep 16, 2010 | 01:25 PM
86camaroZ's Avatar
Car: 86 iroc
Axle/Gears: 370
Engine not warm, throttle not open. I'll recheck a couple tonight with the TB open, but how would i get the thing warm? I already have the headers off. I do own a big kerosene heater, could blow that into the engine bay for an hour or so.
Old Sep 16, 2010 | 02:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I assumed you had it running and could run it for a few minutes at idle, shut down and pop out the plugs to check the compression that way heater may work but even cold should show accurate enough information.
And FYI, i just did some searching on here and it seems that most TPI 305-350's are in the 170-180 range when stock with their cranking compression. So 120-135 is abit low, but you'd see abit less than stock due to larger cam/later intake closing, just dont think it would be that much of a difference.
Old Sep 16, 2010 | 03:07 PM
86camaroZ's Avatar
Car: 86 iroc
Axle/Gears: 370
Thanks Orr.
I'm not putting my hands around those headers after the cars been running for a minute or two. You can gladly come over and do that part for me
Old Sep 16, 2010 | 04:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
been there done that.. no thanks you can borrow my welding gloves, they should help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
