Head help TFS-31400001
Old Sep 20, 2010 | 01:24 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
had on my camaro and plan on putting on my 350. made damn good hp on my mild 305. but i know nothing about these heads other then there were two versions. the G1's and the others. can someone help me out and get me some information on them. wanting to run a cam but dont know the lift i can put on with stock bottom end. please help
Old Sep 20, 2010 | 08:19 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Head help TFS-31400001
So your concern is how much lift you can safely run? That's somewhat dependent on the lobe separation angle ground into the cam, and somewhat dependent on your installed position, the intake center line.
Your heads are limited mostly by your choice of springs. Your pistons have valve reliefs, but they're probably sized for 1.94" valves.
So, just how insane of a cam are you hoping to install, anyway? With a stock bottom end, you really can't reach for high rpm.
I'm guessing you're thinking of an XFI280HR, but that's ridiculous. Shoot for a 218/224-112, 495/503 or something like that.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
