Custom Cam Engine Dyno Program from Cam Quest
Old Sep 20, 2010 | 08:38 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
I recently found this on the internet, and I can't figure out how to work it but its supposed to make it to where you can change specs around for your cam to anything you want and adjust timing etc.... Let me know if someone gets this and can use it. I would like to try, but for some reason I cannot find step 2 (target) on my lap top. You will need Comp Cams Cam Quest to do this. This is off the Mopar Forums in case your wondering and they have been able to use this... Ok...
Just found a way to enter custom cam info if you're using this program.
First, build your engine in Camquest, and find some comp cams # that comes up as a possibility for your motor. Write the # down, example 21-225-4. Pick a comp cam that you don't intend to actually use (or want to compare against), since you're going to change its specs. Save your engine and exit Camquest (you can stay in, but you'll have to exit and open again to see your new cam).
1. Find the shortcut to open the program; right click on it and choose "properties"
2. Click on "Find Target"
3. Go into "Manuals & Videos" folder
4. Go into "Menus" folder
(you may want to make a backup copy of CompCamsData6.txt now in case something goes wrong. Press CTRL-C, then CTRL-V to make a copy).
5. Click on "CompCamsData6.txt" to open it with notepad or another text editor.
6. Press Ctrl and F to open the find dialog.
7. Enter the # you wrote down 21-225-4 and press enter.
You will now see something that looks like this:
Chrysler 383-440 C.I. 8 CYL. 1959-1980 "Hydraulic-Street / Strip, needs 2800+ stall 9:1 comp, rough idle." Yes Yes Yes Yes
Xtreme Energy™ Hydraulic Flat Tappet Camshafts Hydraulic Lifter Hyd. Hyd. 2300 to 6500 21-225-4(Single Bolt)
XE284H 284 296 240 246 0.507 0.51 110 106.0 K21-225-4 SK21-225-4 [7] CL21-225-4 [7 ] Not Applicable 822-16 [61]/867-16
[37] 2104/3104 1321-16 [23]/1071-KIT [23] pg. 278-279 911-16/925-16 [2] 741-16 627-16 [27] 505-16 [2]
Now you can change the values in bold. First thing is change the model (XE284H) to the name of your cam (e.g. Isky292 in my case) so that you can spot it easier in the cam quest program. You could also change the description if you want.
Now change the rest of the values to match your cam.
They are (all intake then exhaust)
Seat to seat duration, .050 duration, lift at valve, intake centerline, lobe centerline.
The safest way to do these edits is to highlight the numbers you are going to change (and only those numbers) then type in your numbers which will overwrite the old ones but will not change any spacing which could goof things up.
Save the file when you're done (CTRL and S) or File>Safe.
Now open Camquest, open your saved engine, and you'll see your new cam specs there with an updated dyno sheet.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
