In the middle of a H/C swap. I have some questions.
Old Sep 21, 2010 | 03:48 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys I'm finally putting the ZZ4 heads and cam in and I have a couple of questions.
First, I got a timing set from Napa and I'm not to sure of it. Here's the one I got.
http://www.napaonline.com/Search/Det...+50012+2012008
Will I be ok using this?
Second, This is for those who have done this swap. What did you guys do for the sensors in the heads? My stock ones look to be a little larger than what the plugs seem to be.
Third, being the the ZZ4 cam is a roller cam I shouldn't have any problems with my stock distributor gear will I?
Also, what would be a good header gasket for these heads? I'm currently running 2055's. I plan on getting a set of Dyno Don headers here soon.
At this time that's about it but if anybody can help me out that would be awesome.
Old Sep 21, 2010 | 10:20 PM
Re: In the middle of a H/C swap. I have some questions.
Hello? anybody? a little help here?
Old Sep 21, 2010 | 10:27 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
No application data for that chain, but looks like it should work, looks just like a SBC timing chain lol...
The sensor issue...they should swap over, id have to see them to know or not..
If you're using the original 88? distributor...it will work just fine with the zz4 roller cam.
ive always had great success with percys aluminum header gaskets..wont blow out, and they are reusable, 35 bucks a set.
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
usafirebird
Sep 29, 2015 11:58 PM
raymondandretti
Sep 27, 2015 06:43 PM
